It is currently Mon Aug 04, 2025 12:58 pm
PostPosted: Wed Feb 18, 2009 6:10 pm
In the thread on bridge positon, Dennis Leahy wrote:
"I read the Siminoff book too, and he showed how he determined that the bridge was primarily rocking (fore and aft), and my fuzzy understanding (don't really know where I got it) is that archtop guitars (but not flattop steelstring guitars) primarily transmit vibrations via a pumping action. Again, I know where I got the notion that "stopped" (typically bridged) steelstring flattop guitars primarily rock the bridge - it was Siminoff's book.
So, I'm betting that Al Carruth has set up his own experiment and came to a different conclusion - and I'd love it if Al would show us how he arrived at that. Maybe if we keep bugging him... "
Im sorry i missed that the first time, and have been asked by another poster to reply specifically to this. Sadly, the 'reply' button seems to be broken, so I'm taking the liberty of starting a new thread.
I have not read Siminoff's lastest book. I've heard a lot about it, and I probably should spend the money to get it, but being a typical impecuneous luthier, I'm loath to do so.
I did spend 'way to much time, spread over several years, measuring the forces that a plucked string puts on the top of the saddle as it vibrates. Part of the reason it took so long was that I can't afford to spend lots of time or money on this stuff, but mostly it was just that I was sort of feeling my way along, and didn't have a faculty advisor to help figure out the problems that came up. This was compounded by the fact that strings are not nearly as simple as we are often lead to believe, and I kept seeing stuff that wasn't supposed to be there. Many of the gory details (minus some of the more gory gore) are to be found in the article on string forces I published in 'Guitarmaker' magazine after the '07 Symposium. Sadly, we got in a bit of a hurry, so some of the charts are hard to see, and one or two are missing. Stuff happens, I guess.
Summarizing in desperate haste(supper's almost ready):
I made up a heavy beam of persimmon wood, with a 'nut' and 'bridge' on it. These contained piezo elements, set up to read the transverse (vertical) and tension change forces of the string as it moved. The string was 'plucked' by looping a fine (~#44) wire behind it and pulling upward until the wire broke. This gives a constant force pluck at a known place on the string.
What I found was that the transverse force, when the string is vibrating vertically, is, for most strings, much greater than the signal from the tension change. Of course, the ratio varies depending on several parameters, which I discussed in the article. It is also true that real plucked strings don't simply move 'vertically' relative to the soundboard, so the proportions between the two forces can vary over a wide range in practice.
I also measured the 'admittance' at the top of the bridge saddle on a steel string and a classical guitar. I looked at the magnitude of acelleration of the saddle top when it's driven by a constant voltage signal in three directions: vertically relative to the soundboard, horizontally across the top, and horizontally along the length of the strings. There's a lot of detail in this information, of coutrse, due to the complicated resonance structure of the guitar, but basically the admittance was least across the guitar, as you'd expect, and greatest in the vertical direction. Driving along the axis of the strings was harder below abnout 350 Hz on both guitars than driving vertically. Above 350 Hz they tended to swap back and forth. This fits well with the data from similar experiments done by other researchers that I'm familiar with, such as Fletcher and Rossing.
Several years ago I did a very quick and dirty experiment, using a magnet and my signal generator to drive a string in transverse vibration with a pure tone. By altering the orientation of the magnet I could drive the string in any direction from vertically to horizontally relative to the plane of the soundboard. When driven vertically the string can push the soundboard in and out, the loudspeaker motion. When it is moving horizontally it cannot push the top effectively in that way, but it will rock the bridge owing to the tension change. I used my dB meter to read the output of the guitar. Sadly, I did not take good notes of that one: it was just a quicky to answer a post on another forum. What I do remember is that the instrument produced much more sound when the string was vibrating vertically then when it was going horizontally.
So, from my data, it seems as though it's easier to drive the top vertically, like a loudspeaker, than it is to rock the bridge. The strings themselves produce a stronger signal in the vertical direction than they do along their length in tension change. Finally, the top is more efficient in producing sound when driven like a loudspeaker than it is when rocking the bridge.
This, then, is the basis for my disagreement with the statements attributed to Siminoff. I'm perfectly willing to say that there are most likely difficulties with all of my experiments. However, they're the best I could do. I take some comfort in the fact that my results do agree with those of the best authorities I know of, but argument from authority is one of the weakest sorts. If anybody wants to duplicate my experiments, and improve them, I'd be happy to help out: I can tell you about a lot of things that you shouldn't do! But until somebody comes up with solid results that contradict me, I'm sticking with my opinion.
I hope this does not come across as ill-tempered. As I say, supper's ready, and I'm in a bit of a hurry, but I wanted to clear up that point since I was specifically asked to.
PostPosted: Wed Feb 18, 2009 6:45 pm
Once again, thank you, Alan.
PostPosted: Thu Feb 19, 2009 8:26 am
Alan - just wanted to say I always like to read your posts and I've learned a lot from them over the years. I remember the 'string plucked with the magnet wire' experiment from the other forum. This kind of work helps us to better understand how these marvelous stringed machines work and also helps to dispel some of the myths out there- thanks!
PostPosted: Thu Feb 19, 2009 3:05 pm
Alan,
If I read you correctly, It seems that you and Simminoff have actually come to similar conclusions for the case where you pluck parallel to the soundboard- that the rocking of the bridge is a significant component of sound production.
Sure, If you pluck away from the soundboard that is not the case, but that is not how we play a guitar (as opposed to say a Kora)
I am no fan of Simminoff- bought his book and felt I had wasted my money. He says some frankly silly things from a scientific and engineering viewpoint, but the bridge rocking aspect seems to have some merrit.
If I am misinterpreting you please say so.
regards
Jeff
PostPosted: Thu Feb 19, 2009 3:42 pm
What about using high speed cameras, and 3" 'Pin-markers" to see the vibrations? You could attach the pins at different points on the bridge, top, back, and the 3" length would magnify movement for the camera.
Of course, getting hold of a million dollar high speed camera is not easy.... idunno
PostPosted: Thu Feb 19, 2009 5:06 pm
City: Duluth
State: MN
Al,
Thank you very much for taking the time to explain your experimental setup, and your conclusions. I really appreciate it!
Dennis
Dennis Leahy
Duluth, MN, USA
7th Sense Multimedia
PostPosted: Fri Feb 20, 2009 2:45 pm
Jeff Highland wrote:
"Sure, If you pluck away from the soundboard that is not the case, but that is not how we play a guitar (as opposed to say a Kora)"
Well, the pick or fingertip move sideways, but the string might not end up going that way. If you think about it, you do push the string downward at least some when you hit it with the pick, and Taylor, in his book "Tone Production on the Classical Guitar", spends a lot of time showing how to get the most 'vertical' motion out of the pluck, which he says gives the best and loudest sound.
In practice, we usually end up with the string moving at some angle to the top, neither fully horizontal nor perfectly vertical. Thus we get some mix of forces. Fred Dickens pointed out to me years ago that it's often possible to watch a string going from vibrating in one sense to vibrating in the other. The arc 'precesses', if you will. He thought it might have something to do with torsional vibration in the string, induced by it rolling off the end of the finger. I noted in my experiments that strings on my rigid rig didn't show this behavior, so I think it may have to do with bridge/top motion.
And, after all, if the string was NOT vibrating vertically, why would it ever buzz on the frets? :)
PostPosted: Fri Feb 20, 2009 3:09 pm
Along these same lines, there are a few You Tube videos on the Presti method of plucking the classical string. It is pretty good at explaining the stroke that produces a more vertical vibration of the string vs a lateral vibration, and why the downward stroke is better than pulling up on the string. It's pretty simple stuff, but it helps to see it happening.
Users browsing this forum: guitarjtb and 36 guests
